cable_guy_212 |
07-08-2013 03:29 PM |
transmission stuck in limp mode
I have 2001 caravan sport 3.3 liter engine i changed the alternator and battery. That's when i started hearing problems. First i assume it reset the computer because the signals and all thatdiddent work figured that out. So i jacked it up got both fronts wheels of the ground and drove it with the wheels of the ground. To click off some miles before inspection. Cause in bc before you can ga tag you have to get a three day inspection pass. So i was trying make sure i diddent have to many not ready and fail the emissions. Put twenty miles on it worked just fine. Went got more gas drove around the neighbor hood bout ten more miles fine. Hit the rd for inspection 50 yards check engine lite no shift. Took it to the parts store they scan it i get p0700 and p1767 i Google relay stuck open i fix go back to day and they give me codes p0700 p1767 andp1768 which tells me relay always on and relay always of. I have reset the computer since changing the relay now the new code with the old codes. I don't know what else ti do i dint have the money to put in the shop. Could it be the shift solenoid or tcm or the new relay bad. I can't get out of limp mode even after resetting the computer i start it and in back where i started without even putting it in gear. Dodge caravan sport 3.3 l overdrive transmission 4 speed 135500 milesthank you
