1999 dodge carvan
Old Jul 11, 2013 | 09:03 PM
skyjoe53's Avatar
skyjoe53
Default 1999 dodge carvan
I have a 1999 dodge carvan been trying to get things fixed on it and i dont know why my passnger window switch dont work i replaced it but it still dont work but i can work the window from the driver side does anybody have any clue why its not working
Old Jul 12, 2013 | 01:17 PM
Cougar41's Avatar
Cougar41
Check for 12vdc power at pin #1 at the switch (tan/dark green wire), key at on or acc. If it's not there find the break between the switch and the junction block fuse panel under the dash.
All power is supplied by two PTC circuit breakers. Other windows work so it's not that. Left and right switches use a different power path. All windows use the same ground.
