Stereo Wiring Diagram
Does anyone know how I can get a wiring diagram showing the connector pinouts for the stereo in my 2008 Grand Caravan SE. I have a 4 speaker unit that doesn't have a separate amplifier. Installing aftermarket stereo and have some doubts about connections.
Try here
http://www.revbase.com/BBBMotor/Wd/R...dSubsystem=903
Here is the main page to the site.
Thanks for reply. Interesting, when I select 2008 Grand Caravan on the 2nd link, it only shows the 3.8 and 4.0 engines. Mine is the 3.3. Also, what I'm looking for is the pinout at the harness connector. I'm not an audio expert, but these diagrams seem a bit beyond my abilities. But, I'll keep studying them and maybe the fog will lift.
Thanks for the help guys.
I was moving a Kenwood DDX7017 HU from my Miata into my GC and was perplexed about the wiring connections. Felt that having the GC's info would help me, esp. since the harness I bought, which was the one designated for my GC by 3 sellers (including Crutchfield) didn't use the same terminology as the diagram for the Kenwood. Also, my call to the manufacturer's tech line met with the response that the harness wouldn't work with the GC's CANbus. Relying on sellers' info, I proceeded anyway and took reasonably educated guess at connections and was successful. Then, I got a delayed response to my earlier emailed inquiry to Mfg'r's tech saying that I guessed right except as to one wire. Made the change he suggested and system working fine. (Don't know how big difference the change made, but went along with it. Also told him about what I was told by other tech on phone and that harness works fine)
Note: since the Kenwood doesn't have an AUX connector on the face, I used the audio cables for the Video-In to to run an external hookup for my MP3 player so I can listen to my audio books.
Thanks again.
Thanks again.
