2011 Grand Caravan R/T - Add NAV & Uconnect question
Just purchased a used 2011 Grand Caravan R/T and it has the Uconnect radio but no GPS or Uconnect features.
It has the Sirius radio and when I start the vehicle the radio says Dodge Uconnect but there is no uconnect.
Is there anyway of adding these features to this vehicle?
like... an hour worth of physical work, and 15 minute of Reprograming with a Dealer scan tool.
The U-Connect Kit plugs in behind the Radio, and you remove the A-Pillar to snake a Microphone wire behind it from the U connect module.
Anyway, did you know you can just buy an AUX cable, plug the Phone's headphone jack into the Radio, and it'll work just like a blue tooth. If you are going to use a Smart phone as a NAVI unit mounted on top of the Radio alrdy, why not plug it into the Radio and listen to music and pick up calls on it too? Vo
