92 Dodge Caravan Strange Voltage issue.
Old Sep 1, 2013 | 11:29 PM
teleman's Avatar
teleman
Default 92 Dodge Caravan Strange Voltage issue.
I'm new to the DF. I have a 92 Dodge Caravan witht the 3.3l. My voltage is reading low with the van running. 12.3v. I have put a new alt on it, done the voltage regulator bypass kit and still have the same voltage reading of 12.3-12.5v with the van running. The resting voltage of the battery is 12.9-13.1v van off. If I use a 2nd battery that is not tied to the vans electrical, I get 14.5v with the van running. Basically running a charging wire from the alt to the 2nd batt only and the 12+ from the regulator. Any help or info would be greatly appreciated. Thanks.
Old Sep 2, 2013 | 02:47 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Stick the test leads into the copper of the cables instead of touching the battery terminals and see what you get. You may have a voltage drop in an old terminal or your battery could be crapping out.
Old Sep 2, 2013 | 11:41 AM
teleman's Avatar
teleman
The battery terminals good. The battery has threaded post. I have narrowed it done to the 3 wires that is in the fusable link. 2 are solid red and the other is red/white. These 3 wires have to be connected to 12+ for the van to run. However i cant tell what else is all connected to these 3 wires. I do know that the R/W goes to 2 of the relays on the fender. The solid red goes to one of those relays also. It almost seems that i have a short to ground somewhere. But I would think if there is a short something blow or burn up.
Old Sep 2, 2013 | 12:18 PM
TNtech's Avatar
TNtech
Yep, I remember those. We don't see that generation at all anymore, but it's what I started out on in 92 when I hit the door. What will throw you is the links will blow but the insulation on the outside can still look perfectly intact. Just get a good test light and work your way from one end to the other at different spots and you will find it. Maybe like every 2 or 3 inches.
Old Sep 2, 2013 | 12:59 PM
teleman's Avatar
teleman
Is there a way to test for a short while the van is running? I have checked with the van off and no short that I could tell.
Old Sep 2, 2013 | 02:37 PM
teleman's Avatar
teleman
Ok. So I have checked the resistance from ground wire on the battery to the alternator. I'm getting about 15ohms. Shouldn't it be closer to 0?
Old Sep 2, 2013 | 09:46 PM
teleman's Avatar
teleman
Well, I did figure out that on the negative wire disconnected from the battery. And the Pos. wire connected to the battery, I get 12.8v+ on the negative wire. Is that a sign of a short?
Old Sep 3, 2013 | 08:58 PM
TNtech's Avatar
TNtech
Should be less than 5. Less than 2 really. Make sure to have any wire you're checking for resistance disconnected from it's termination at both ends.
