No start -Transmition replacement
Old Sep 16, 2013 | 04:28 PM
roberttyrrell714's Avatar
roberttyrrell714
Angry No start -Transmition replacement
Just replaced trans wife's Caravan. 2001 3.8 121,134k. Due to notorious "bump stop" and losing reverse. Replacement went smooth considering I did it on jack stands . Autozone&Advanced said "it couldn't be done".
Won't start.
I'm Getting error codes P1684 oil pump poss sensor. P0320 speed input sensor? checked connections tight/ O.K.
Any Ideas?
Old Sep 16, 2013 | 04:36 PM
roberttyrrell714
P.S there were NO previous data or codes on either sensor prior to replacement.
Old Sep 16, 2013 | 04:56 PM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
well think If u either forgot connections? can u remove those sensors from previous tranny? might have bad sensors on the replacement transmission.
Old Sep 24, 2013 | 08:39 AM
RobertTyrrell's Avatar
RobertTyrrell
Default thanx
Thanx, I ended up replacing the crankshaft poss sensor. Apparently the P1684 doubles as no start w/in 50 attempts? cleared code.
Now I need to have it quick learned. 1st to 2nd a little jumpy.
Not bad for never replacing a trany before.
