Headlight bulb problem
Old Oct 13, 2013 | 06:45 PM
Don Kondra's Avatar
Don Kondra
Default Headlight bulb problem
Greetings,
I recently purchased a 2008 Dodge Grand Caravan SE and it's obviously time to change the headlights.
Decided to install Sylvania Silverstar Ultra's.
Problem is the old bulbs are a two piece, the bulb itself and a male connector. The new Ultra's are one piece.
Pulling out the red clip does not release the male part of the bulb assembly.
Of course I tried prying it out and the plastic simply snaps off. But then I can see where I can insert a screwdrive to lift the lock but you need three hands.
One to hold the lock up, another to hold the assembly and the third hand with needle nose pliers (?) to pull out the connector.
Silly question, is there a "trick" to do this ?
Cheers, Don
Old Oct 14, 2013 | 07:11 PM
Don Kondra's Avatar
Don Kondra
And the answer is....
The ends of the jaws are rounded and easily slipped under the lock.
Cheers, Don
Old Oct 15, 2013 | 12:20 AM
2therock's Avatar
2therock
I hit the link but it endlessly had the loading animation.
Anyways, thanks for following up.
Old Oct 15, 2013 | 12:45 AM
Don Kondra's Avatar
Don Kondra
You can't see the picture of the surgical clamp embedded in my message ?
Try this > http://i249.photobucket.com/albums/g...psc9631b2a.jpg
Cheers, Don
Old Oct 15, 2013 | 10:51 AM
2therock's Avatar
2therock
No embedded. Its gotta be a link here. Not sure what you did but the link works.
Never seen connectors like that.
