how to adjust 2013 caravan headlights
Old Oct 14, 2013 | 12:12 PM
davidsantini's Avatar
davidsantini
Default how to adjust 2013 caravan headlights
need help on how to adjust the light i don't see any way unless they are hidden
Old Oct 14, 2013 | 03:26 PM
Tizzy1's Avatar
Tizzy1
On the rear of the headlamp housing about between the high and low beams is a white plastic looking screw. That is the vertical adjustment. I believe you need HID in order to get the horizontal adjustment which would be accessed through the hole in the fender. You can kind of see where it would go on the right housing.
Old Sep 29, 2014 | 11:39 AM
Darkside 700's Avatar
Darkside 700
Are their separate adjusters for the low and high beams ?
All I can find is the one for the low beams and my high beams need to be lowered but cannot find the adjuster screw for them.
Old Sep 30, 2014 | 11:08 AM
Tizzy1's Avatar
Tizzy1
It adjusts the entire housing. Only adjustment specs for the low beam. If low beam is correct, high beam should also be correct.
