2004 dodge caravan heater fan
Old Oct 27, 2013 | 09:48 PM
stevie's Avatar
stevie
Default 2004 dodge caravan heater fan
2004 dodge caravan, turned heater on for first time since last spring and fan does not come on at any speed. Doesn't make any kind of noise. Any help is greatly appreciated
Old Oct 28, 2013 | 03:20 PM
Tizzy1's Avatar
Tizzy1
Plenty of threads on here for blowers on that model. Blower motor gets hard to turn and then blows the resistor. It is located behind the glove box. Should have power to the green wire in the 2 pin connector. If you also have power at the black wire, the resistor is most likely blown. I would replace the resistor and the motor.
Old Nov 9, 2013 | 09:07 PM
samtheman's Avatar
samtheman
I replaced the resistor and that took care of the problem. 10 minute job, Thanks for all your help , I appreciate it
