2008 Dodge Grand Caravan SXT 3.8 (Radiator Fan Relay Question)
Old Oct 30, 2013 | 08:23 PM
tthams's Avatar
tthams
Angry 2008 Dodge Grand Caravan SXT 3.8 (Radiator Fan Relay Question)
I am looking for anyone that can specifically tell me where I can find the high speed radiator fan relay. All the posts are telling me different spots. I have a 2008 Dodge Grand Caravan and this morning I hit a pheasant on the way to work. The radiator fan won't turn off now. I am hoping it is something simple. I hit the pheasant on the driver's side of the van and wondering what the hell I did to cause the relay switch to go? I can't seem to find it. A pic shows it to also have a heat sink and that is what I am looking for. Any help with where exactly I can find this would be appreciated.
Thanks,
Troy
Old Oct 30, 2013 | 10:42 PM
Welcome to DF. Moving this to the Caravan section.
Old Oct 31, 2013 | 02:20 AM
Cougar41's Avatar
Cougar41
Where ever it is it has 4 wires in the connector:
Brown with Lt blue tracer (stripe)
Brown / orange "
Red / brown "
Dk Blue / violet "
Only the last one goes to the fans. The other three connect to the TIPM.
Old Oct 31, 2013 | 11:05 AM
Tizzy1's Avatar
Tizzy1
Service manual shows it down by the left headlamp connector
Old Oct 31, 2013 | 12:49 PM
kallsop's Avatar
kallsop
Don't know if the '08 T&C LX 3.3L has the same wiring. Left of radiator?
Old Jan 5, 2015 | 09:04 PM
jammarakc's Avatar
jammarakc
Need help on 2008 T&C touring with the 3.8. Had a radiator leaking so I replaced it with a new one from the dealer. After I install it I took it for a test drive and noticed that it was running hotter than I remember. When I got home ,with the engine still running, I open the hood and noticed that the cooling fan was not on. I found both relays and checked them ,out of the car, with battery voltage and the relays clicked and contacts closed. I also applied batt. voltage to the output contacts of both relays and the fan operates as it should, low and high speed. Also the low speed did click on, after a few cycles, of the A/C being turned on. I'm thinking that something is wrong and that may be why I had replace the rad. But don't know where to go from here. Thanks in advanced.
