[5th Gen : 08+]: 2010 grand caravan battery?
Old Dec 1, 2013 | 09:50 AM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
Default 2010 grand caravan battery?
hey guys looks like mine starting to have issues with battery or no start. yesterday I notice I started the vehicle and left to go to a family house. stoped at a place on the way. had the vehicle off for not more than 2 to 3 mins. decided I go fill up so I cranked it and it seemed it would not start.
died. the second try it started up but barely. I let it sit idling cause I did not want to be stuck. I hope its something to do with battery or alternator not the dam key safety stuff cause soon to be out of warranty.
what can I do to verify a battery?
edit. also if I replace my battery can I go a bit higher like 50 or 100 cold cranks? does it matter? damage anything?
Old Dec 1, 2013 | 07:31 PM
Cougar41's Avatar
Cougar41
Make sure the battery connections are clean and tight. Using a voltmeter ($15 at Walmart/kmart) check the voltage at the battery posts engine off. Should see a minimum of 12.1 volts dc. The best battery test? A load test free at many auto parts stores. A basic alternator check? Start the engine and measure the voltage at the battery again. Should see 13.5 volts dc minimum.
The more CCA the better. Won't hurt anything.
Old Dec 2, 2013 | 06:29 PM
DodgeCaravan2010SXT
I had 12.6vdc off and car running was like 14.6vdc. I think looks good to me. not sure why It acted strange like that. was not like car was parked for more than a day without being driven. although was cold out that night.
I have a fluke 87v
Old Dec 2, 2013 | 07:46 PM
Montreal300's Avatar
Montreal300
Good numbers. Was the red security light flashing?
Old Dec 3, 2013 | 06:32 AM
DodgeCaravan2010SXT
not that I could recall. happened quick. I kinda was paying attention to the start so I backed off the key. should just cranked it and left it but heard the low voltage start that usual when low battery. happened many times in my work vehicle . so I just backed it off. I think I might of turned off the radio, heat and anything before the next start which fired up right away.
strange.
