[4th Gen : 01-07]: 2006 Sliding door won't open
Old Dec 1, 2013 | 03:08 PM
chr_edw's Avatar
chr_edw
Default 2006 Sliding door won't open
Our 2006 caravan driver side sliding door will not open. Can not even unlock from inside.
Any ideas?
Old Dec 1, 2013 | 03:12 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Any ideas?
Open it manually and hit the button to close it. Post what it does.
Old Dec 1, 2013 | 03:30 PM
chr_edw's Avatar
chr_edw
Can not open at all.
Old Jan 13, 2014 | 04:32 PM
J Wikoff's Avatar
J Wikoff
Did this get fixed?
Old Jan 13, 2014 | 09:28 PM
TNtech's Avatar
TNtech
I must have lost track of this thread a month ago. Sometimes I don't get notifications.
First, If the door lock actuator doesn't work (unlock) the door can't be open electrically. You have to fix the dead lock actuator first.
In addition, the most common problems on these generation doors are the wiring harnesses in the track. The ground wire breaks due to repeated use over the years. That wire is ground for the door modules, so you will have no function from them. You can fix the break, but it will surely break in another spot shortly after, so replacing the track harness is the best option.
Old Jan 14, 2014 | 06:21 AM
trophyslayer's Avatar
trophyslayer
I had the wiring harness break, repaired it, lasted a year, new break, just replace the harness before Christmas,
I also had the same same door lock actuator motor burn up too, thankfully the cost is pretty cheep
now even when my actuator broke, I could still manually pull of the door lock and then open the door,
Old Jan 14, 2014 | 08:28 AM
chr_edw's Avatar
chr_edw
Still not fixed.... I took the panel off and tried manually to un-lock and it is still stuck. Haven't had much time to do more research.
Does anyone have a diagram on the door?
