[3rd Gen : 96-00]: changes gears slowly at first
Most definitely taking you guys advice....im in a holding pattern atm....new job out of town is takin priority ...will update
THANKS again
I did change the filter and fluid. I did disconnect the batt. wires so I dont have a 'check engine' light on atm....
Fluid looked ok, I guess, no LARGE metal particles..i ran my magnet all around the pan before i emptied it, then i noticed it already has a magnet in it....that was kinda sludgy...I cleaned everything really well and put back together fine.
van went through all the gears fine from what i can see...i only drove it 5miles....no tags
I did notice theres some sort of weird noise, mechanical/electrical noise when i change through the different drive positions....a weird electro mechanical noise when i go into drive and reverse.......ssschlllingggg
