[5th Gen : 08+]: rear defogger fuse panel???
Old Jan 9, 2014 | 10:05 AM
mantonesr38's Avatar
mantonesr38
Default rear defogger fuse panel???
I have a 2008 dodge caravan and my defogger don't work??? I've looked under the hood for the fuse box to change the fuse??? I found the fuse box under the hood with no listing for rear defogger... I thought there was supposed to be another fuse panel with fuses inside the vehicle??? I took off the side panels on the dash of the van and not there??? I took off all the panels underneath the front dash as well to hopefully find it, but no luck??? Where can I find the other fuse panel with the rear defogger fuse please and thank you...
Old Jan 9, 2014 | 02:13 PM
Tizzy1's Avatar
Tizzy1
The fuses are in the fuse block under the hood. There is no other fuse box. The fuse for the heated back window is J14, 40 amp. The fuse for the heated mirrors is M35, 10 amp
Old Jan 10, 2014 | 01:14 PM
mantonesr38
Default Thanks for the reply...
I know where the fuse box is at... But there is not one thing that says "rear defogger"??? I seem to be missing a fuse in one spot of that panel??? should I put it in there???
I got a 40 amp, but there is nothing that says j14??? thinking I would find that J14 as stated...
also there is nothing that says heated mirror m35???
But there is a fuse for a automatic rear door opener with a 40 amp fuse in it, but yet I have no automatic doors at all??? should I change that fuse with a new one to see if that is the problem???
Thanks so much for the help and will look for your reply...
Old Jan 13, 2014 | 08:13 AM
Tizzy1's Avatar
Tizzy1
The cover of the TIPM should have a picture of the fuse locations and their numbers
