[4th Gen : 01-07]: 03 Caravan Fans stay on high
Old Feb 5, 2014 | 06:00 AM
newfieryder's Avatar
newfieryder
Default 03 Caravan Fans stay on high
HI all
Nice place here I have a 03 caravan 3.3 SE the rad fans both turn on after the engine has been running for a couple of minutes they stay on high and only turn off when I turn the van off
I have replaced the fan relay the one on the front left inner steel bumper
and the temp sensor I call it in the water jacket under the coil the van has ac also it works but I don't here the ac clutch cut in and out like I did
Thanks hope someone can help me
Old Feb 5, 2014 | 11:09 AM
Tizzy1's Avatar
Tizzy1
The fan also comes on with a/c high side pressure. Common for the transducer to go bad. It is located on the liquid line back by the drier. Unplug it and see if the fan stops. They usually fail reading very high pressure.
Old Feb 6, 2014 | 08:13 PM
newfieryder
Thanks alot
Ill try that this weekend and let you know what I find
Old Feb 20, 2014 | 07:23 PM
newfieryder
Hi again
I tried that didnt change anything fans still on high I guess i am pulling the wright plug grey consctor on ac line by the strut tower 3 wires the van runs for about 5 to 8 minutes then they come on and i dont hear the ac clutch click in and out like i did
thanks
