[4th Gen : 01-07]: Need to attach rear vent window back...
Need help! Can't seem to find out what the manufacture used to attach the rear vent motor to the window on a 2005 caravan. The retainer was broken off when someone tried to break in. everything works still just need to reapply the retainer to the window...
PLEASE HELP!
thank you,
Joshua
PLEASE HELP!
thank you,
Joshua
Your missing the piece on the glass? Is the little stud still there? The piece usually comes with the glass but I have had luck removing them and gluing them to the other window. So if you can find one in a junk yard.
Do you just use the same glue used to glue rear view mirrors back on a windshield?
That's why you need to know if it has the stud on the glass. The stud is glued to the glass and then the ball socket screws onto the stud and it is held in place by hot glue or something probably a little stronger. So if you can break the piece loose from the glue you can unscrew it and screw it onto your glass. If the stud is missing, you need new glass.
