[4th Gen : 01-07]: Pressure Solenoid Assembly
Have a 2001 Dodge Grand Caravan with a 3.8 L engine. Check engine light code, P0740 says to replace the Transmission Pressure Solenoid Assembly. Where on the transmission is this part. If on the inside, get it be gotten to without tearing the transmission apart, maybe by just dropping the pan where the filter is?
On the outside front center: http://ww2.justanswer.com/uploads/do...41602_41te.jpg
Keep in mind a P0740 is a TCC solenoid CIRCUIT malfunction. Could very well be the solenoid pack but it could also be a bad wire, connection, TCM or torque converter.
