[5th Gen : 08+]: Dome Lights
Old Apr 17, 2014 | 09:59 PM
YouCantKeepAGoodVanDown's Avatar
Default Dome Lights
Can anyone tell me if the dome lights on my 2012 GC SXT are run from the BCM? I swapped all my map and done lights to LED and now they won't operate correctly, only with the ignition on. I'm trying to decide whether to hardwire the lights or just put the nasty yellow bulbs back in
Old Apr 23, 2014 | 03:25 PM
1wraith's Avatar
1wraith
I have a 2012 and swapped mine out for LED. Mine work fine with the ignition off. Fuse maybe? I'm guessing as I don't know why it wouldn't work.
Old Apr 24, 2014 | 08:11 AM
I contacted the place where I got them and they said there's a small amount of current in the dome light circuit that doesn't get picked up with regular lights and because LEDs are so efficient they pick up on that and cause them to glow a bit.
Anyway he told me to put a 1k resistor across the led bulb to bleed off the current and sure enough it solved the problem.
Old Aug 20, 2014 | 12:11 PM
nyivz's Avatar
nyivz
Default question
How were you able to remove the lens cover from the map light?
Old Aug 21, 2014 | 04:43 PM
1wraith's Avatar
1wraith
If I correctly recall, the whole console comes down and the cover isn't removed. I believe there is another thread regarding this.
Old Aug 27, 2014 | 06:53 AM
nyivz's Avatar
nyivz
so I think I'm having the same issue you're having accept my my life I have in the glue but when it comes to having the courtesy light they won't turn on were you able to fix this at all did the resistor help.
Old Sep 9, 2014 | 03:23 PM
1wraith's Avatar
1wraith
Someone else used a resistor to get theirs to work. I didn't need one for mine. Not sure if it's because my van is an SE model or because of the type of LED lights used.
