[3rd Gen : 96-00]: 98 caravan map sensor
Old Apr 21, 2014 | 07:21 PM
mate's Avatar
mate
Default 98 caravan map sensor
hello, i have a 98 grand caravan 3.3, i'm finding the map sensor signal wire that informs the PCM of the MAP sensor voltage reading as it changes is showing a voltage of 2.8 volts with key on engine off.
I read that it should be about 1 volt on idle and close to 5 volts wide open throttle.
i'm getting 2.8 volts at idle and the van stalls when idle if i give it gas it runs smooth, as soon as a let go of the gas it wants to stall.
does this 2.8 volts @ idle indicate the MAP sensor is not working properly?
this could be why the engine runs better when i give it gas then when i let it idle.
the ground wire and the 5 volt wire test out ok.
Old Apr 22, 2014 | 06:11 PM
mate's Avatar
mate
after much thought i purchased a new MAP sensor and the issue was resolved
Old Apr 23, 2014 | 06:14 PM
Cougar41's Avatar
Cougar41
Nice work. Thanks for posting.
