[3rd Gen : 96-00]: ABS Speed Sensor failure, detect which?
Dodge CaravanThe Dodge Caravan is the best selling mini van from Dodge. How many Dodge Caravan owners here at DodgeForum.com would agree? Discuss it now!
I guess it's going to take a scanner. My multimeter showed no continuity or resistance on any of the sensors from the connector side.. I'm guessing this has to do with some magnet design(spoke on drum assembly pulls sensitive magnet which closes circuit)?
Looking at the diagram you're measuring resistance through a coil of wire between pin #1 and #2 on the connector. The magnet is out of the picture.
I just did the two rear ones that are run through the rubber seals in the floor pan. There was no continuity or resistance on the two pins in the connector..
I was going to do the fronts yesterday but I only see where they go through the wheel well, and the right-from-front one I think has the connector right there, but the left isn't on the well it seems.
