[5th Gen : 08+]: AppRadio 3 on Grand Caravan 2008
Old Apr 29, 2014 | 03:03 AM
dellsam34's Avatar
dellsam34
Default AppRadio 3 on Grand Caravan 2008
I need help gathering all the parts needed for removing stock radio and installing AppRadio 3 maintaining the steering wheel control function, Here is what I know so far correct me if I'm wrong:
1- A device that communicate with the steering wheel buttons via a can bus data-link, I have one already Metra Axxess ASWC.
2- A device that provides switched +12v, reverse and parking signals from the same can bus wires.
3- A radio harness that connects the AppRadio, The OEM car plug and the above two devices all together.
Here is the problem, When I go on metra website I get a list of different devices and harnesses that have similar functionality and they are all compatible with my van and I don't know which one I need, So if anyone out there have a Dodge Grand Caravan SXT 2008 3.8L engine who went thru this already please help.
Here a list of parts just to name few that I have no clue which one to use:
http://www.metraonline.com/part/AX-ADXSVI-CH2
http://www.metraonline.com/part/AX-ADCH100
http://www.metraonline.com/part/AX-ADCH02
http://www.metraonline.com/part/XSVI-6522-NAV
Old Apr 29, 2014 | 07:34 AM
YouCantKeepAGoodVanDown's Avatar
I personally would use a PAC product over Metra. Ive installed many of both over the last 5 years or so and the PAC products are a lot easier to deal with.
http://www.pac-audio.com/productDeta...ProductId=1116
That interface is the one that I used in my vehicle to connect a Pioneer AVHX4000NEX. It has all your necessary connections (parking brake, illumination, ACC, reverse wire, etc) right at the interface and has a built in SWC which is nice.
Old Apr 29, 2014 | 08:09 PM
dellsam34's Avatar
dellsam34
Unfortunatly that adapter is for 2009 and up grand caravan, I do have the Axxess ASWC and XSVI modules that I saved from last car, Just wasn't sure how I do wire them, I will look into PAC adapters and see if I can find an easy one.
