[General]: Dodge Caravan - How to replace Steering Rack
Hi all, I'm interested in replacing you power steering rack and would like instruction on how do perform the job myself. I'm handy and have tools available. How long does the job take and can I do it by myself? 02 Dodge Grand Caravan. Any assistance would be a big help and thanks in advance.
If you want step-by-step instructions I strongly recommend you purchase a Haynes or Chilton repair manual. I was able to find the Haynes for my Honda at a used bookstore for under $10. As an alternative check with your local public library to see if they have the manual you need available to borrow or if they have an institutional subscription to the Chilton online database.
REMOVAL - LHD GEAR
1.Remove cap from power steering fluid reservoir.
2.Using a siphon pump, remove as much fluid as possible from the power steering fluid reservoir. Use care not to damage the filter mesh below the fluid surface.
CAUTION: Locking the steering column in the straight-ahead position will prevent the clockspring from being accidentally over-extended when the steering column is disconnected from the intermediate steering coupler.
3.Position the steering wheel in the STRAIGHT-AHEAD position. Lock the steering wheel in place using a steering wheel holding tool.
4.With the vehicle on the ground, disconnect the steering column shaft coupler from the steering gear intermediate coupler.
5.Raise vehicle.
6.Remove front wheel and tire assemblies.
7.Remove front emissions vapor canister.
8.Remove a single hose at power steering cooler and allow fluid to drain.
9.Remove 2 bolts attaching power steering cooler to cradle crossmember reinforcement.
10.On both sides of vehicle, remove nut attaching outer tie rod end to steering knuckle. Remove nut by holding tie rod end stud with a socket while loosening and removing nut with wrench.
11.Remove bolts fastening leak detection pump to cradle crossmember reinforcement.
12.Remove both outer tie rods from steering knuckles, using Puller, Special Tool C-3894–A.
13.Remove the lower control arm rear bushing retainer bolts located on each side of each lower control arm rear bushing.
NOTE: The bolts fastening the cradle crossmember reinforcement are of two different thread sizes. Note the location of the various sizes.
14.Remove the bolts attaching the cradle crossmember reinforcement to the front suspension cradle crossmember. Remove the 2 bolts fastening the reinforcement and rear of cradle crossmember to the body of the vehicle. Remove lower rear bushings, then the reinforcement.
15.If the vehicle is equipped with All-Wheel-Drive, remove the power transfer unit.
16.Remove tube nuts and power steering pressure and return hoses from the power steering gear.
17.Remove the 3 bolts and nuts mounting the steering gear to the front suspension cradle.
NOTE: The next step must be done to allow the removal of the steering gear from the front suspension cradle. The steering gear can not be removed from the vehicle with the intermediate coupler attached to the steering gear.
18.Lower steering gear from suspension cradle enough to allow access to the intermediate coupler roll pin. Install Remover/Installer Special Tool 6831A through the center of the roll pin, securing with the knurled nut. Hold threaded rod stationary while turning nut, this will pull the roll pin out of the intermediate coupler.
19.Separate the coupler from the shaft of the steering gear.
20.Remove the power steering gear from the vehicle.
5.Raise vehicle.
