[4th Gen : 01-07]: 2005 Grand Caravan Upper Radiator hose
Old May 29, 2014 | 11:53 AM
greekbuckeye's Avatar
greekbuckeye
Default 2005 Grand Caravan Upper Radiator hose
Hello,
I just purchased a 2005 Grand Caravan 3.8L and I have had to replace my upper radiator hose twice due to a pinhole leak in the very middle both times. Is this just a brand issue or is this a common occurrence due to pressure or something I'm not seeing. Help is greatly appreciated!
Thanks.
Old May 29, 2014 | 12:54 PM
Tizzy1's Avatar
Tizzy1
where did you get the hose from? Haven't replaced a radiator hose on a caravan in a long time
Old May 29, 2014 | 02:23 PM
Cougar41's Avatar
Cougar41
I'd go with the brand of the hose unless it's chaffing against something. Very unusual. Could be just a manufacturing defect in a particular run of hoses. What's the brand?
Old May 29, 2014 | 10:40 PM
kuyabribri's Avatar
kuyabribri
Could you also possibly be kinking the hose a little bit on installation? Not caused by wrongdoing on your part but a badly molded hose. I know it's a remote possibility but in my experience hoses from the local parts stores don't always fit perfectly or you are meant to cut a few inches off one end to get it to fit (so they can sell the same hose for multiple different vehicles).
I only buy OEM or Gates hoses and belts for my cars. If you do it right you can find Gates hoses pretty cheap on Amazon. The only time I have ever had an OEM or Gates hose go wrong was because the hose had over 15 years and over 200,000 miles on it.
Old May 30, 2014 | 07:47 AM
greekbuckeye
Thanks for the tips guys it is in the middle of the hose and was the cheap brand from auto z so I'm thinking manufacturer. I have now purchased a gates hose off amazon. Thanks again.
Old May 30, 2014 | 10:56 AM
cv2003's Avatar
cv2003
As the other guys have already said, it's really unusual to see a hose leak these days. And IMO, 2 leaking in the same place is way out there. Did you actually see a break or hole in either of the 2 hoses? If not, is there a possibility that this is a pressurized pinhole spray coming from somewhere else, and hitting the hose in the spot where it's "leaking"? (the rad would be the first suspect).
Old May 31, 2014 | 05:18 PM
greekbuckeye
Thanks for the tips. I will look in to it being the radiator.
