[5th Gen : 08+]: Car did not start.
Old Aug 23, 2014 | 09:40 PM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
Default Car did not start.
ok something really weird happened today. I had to go downtown like 40min drive. some of the drive was slow in the highway in the city. stop and go. usually the needle of the coolant is 1 line below the middle. not sure if this is relevant. it bounced to 1 line above the middle mark then came back down. ok little over heating due to the stop and go. so I arrived at the location and I parked. that's when this happened. I needed move up the vehicle and I turned it on, it started to crank like I lost total power of a dead battery. I hit the gas and keeped it on. it fired up after a while doing this and rpm like hit 4000 even after I released the peddle. so let it sit for a bit running. thinking I let it charge battery possibly. so I turned it off and re tried and it basically back to normal fired up. not exactly sure what may of caused this. will check voltages tomorrow and battery connections too.
Old Aug 26, 2014 | 03:20 PM
DodgeCares's Avatar
DodgeCares
I would start with checking the battery as you stated. Keep us posted.
