[4th Gen : 01-07]: How to fix radio speaker's in my 2001 caravan?
Old Sep 12, 2014 | 06:40 PM
Toney's Avatar
Toney
Unhappy How to fix radio speaker's in my 2001 caravan?
My dash speaker's work,but my door's and rear speaker's will not.I put in another radio the speaker's still will not work.I checked the fuses under the hood,all good.What now?
Old Sep 18, 2014 | 08:51 AM
blaqyukon's Avatar
blaqyukon
you have to check the wiring harness, here a way to check them use a nine volt batt and take the harness loose from the radio end, you might have cut the wires, but in the installer world we call it poping the speakers take 2 leads and conect them to the batt it will make a poping sound, showing the wires are connected, to check for wiring speak wire color codes good it, i have the color chart but am not home right now, am responding because i know u might now like to wait for answers like my self. i post something about motor swapping and i havent heard nothing, anyway i will check on you later..
Old Sep 18, 2014 | 08:57 AM
blaqyukon's Avatar
blaqyukon
i found something for you, listen always let google find what you looking for, they claim u cant install a double din radio i have a 7" screen nav system in my 2001 grand caravan, ive been a stereo installer for 25 years custom work also, i wont lie its a lot of work but its done i will post pics later,,
2001 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Gray/Red
Car Radio Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Chassis Or Metal Strap
Car Radio Illumination Wire: Orange/Tan
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Gray/Green
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Black
Left Rear Speaker Positive Wire (+): Green/Black
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Black
Right Rear Speaker Negative Wire (-): Gray/Pink
Old Sep 18, 2014 | 09:09 AM
blaqyukon's Avatar
blaqyukon
Post How to fix radio speaker's in my 2001 caravan?
this post is for toney
the best way to wire up any radio thats not oem is by the metra wiring connectors, and if u need remote turn for amps or antennas the radio supplys them, the old school way is use the ing wire, but toney i found a link for those radio connectors
http://www.crutchfield.com/p_1207018...7221305&awdv=c
