[4th Gen : 01-07]: Caravan Cold Start Rough Idle
Old Sep 19, 2014 | 11:35 PM
mp2000's Avatar
mp2000
Default Caravan Cold Start Rough Idle
I have a cold start engine miss that is eluding me. It lasts 30-90 sec. Started about 2 months ago. Otherwise, no detectable issues.
2001 Grand Caravan 3.3 Flex
Here is what I have checked and/or replaced:
60,000 miles since engine overhaul
Cleaned TB
No leaking injectors
Ignition good
EGR good
No intake leak
The Snap-on is showing multiple cyl misfire, evap leak (which has been there well before this problem), and catalyst failure.
The live data shows map 19-20Hg, tps .67, st fuel trim -15% to -10% and upstream O2 running high during rough idle.
Fuel economy is a little below normal.
I am guessing something is going bad, but I do not want to throw parts at it. Any ideas?
All I've got is a lazy sensor (O2 or Map), or lazy part (injector or iac).
The rough idle lasts as long as closed loop should kick in, but I don't know if that is coincidence or not. Maybe a part that needs to warm up a bit to work.
I'm stumped.
Old Oct 5, 2015 | 02:19 PM
VMAN's Avatar
VMAN
I had this problem with my 03 3.8L GC. I treated the fuel injectors via vacuum hose with SEAFOAM. I was amazed at how much smoother engine is running now. And before it would stall out from idle, now idle is a lot smoother. Any engine with 100K + miles is going to have carbon build up.
