[5th Gen : 08+]: 2009 steering rack help needed
Old Sep 26, 2014 | 02:02 PM
mrsats's Avatar
mrsats
Default 2009 steering rack help needed
Well great forum for info as always, however most of the threads I found were for 3rd/4th gen caravans. I need a little help on a 5th gen 2009 grand caravan 2009 rack which ran out of fluid, so I topped it up, bled the system and it disappeared again... all of a sudden it started simultaneously leaking out of the boots on both ends. My best guess is a valve failed in the rack somewhere and pumped it into the boots till it couldn't hold it anymore... and that might explain the simultaneous leak at both ends??
Anyhow... if someone has experienced this or knows what is going on, I could use some advice as to if it is a fixable valve or if I have to replace the whole rack. I see rebuild racks are about $250 - $350 but I cant seem to find any shop instructions/tips on replacing it on my own or is it a shop job??
Rebuild an engine, swap a tranny... I am in, never done a rack so again any info would be greatly appreciated.
