[5th Gen : 08+]: 2010 Caravan Audio System Issue
Hi,
First post and new member here. I am having an issue where there is no power whatsoever going to my audio system in my 2010 Grand Caravan. I have the touch screen model and there is no clock, nothing, just a black screen. I have checked the fuses as shown in the diagram in the manual and they all seem to be good. Does anyone have any idea what the problem might be?
Thanks
Matt
Thanks
Matt
Hi,
Thanks
Matt
Thanks
Matt
Did you check the radio connector to see if it is loose or corroded? If no problem found, then you may need to see the dealer to see if it is the radio itself.
Thanks
Matt
This procedure shows the location of the radio & antenna connector.
REMOVAL
1.If radio is equipped with an internal hard disk drive (HDD), perform a complete backup of user data,(Refer to 08 - Electrical/8A - Audio and Video - Standard Procedure) . 2.Disconnect and isolate the negative battery negative cable. 3.Remove the instrument panel center bezel. (Refer to 23 - Body/Instrument Panel/BEZEL, Instrument Panel - Removal) . 4.Remove the radio mounting fasteners. 5.Disconnect the electrical connectors.CAUTION:Pulling the antenna cable straight out of the radio without pulling on the locking antenna connector could damage the cable or radio. 6.Disconnect the antenna cable(s) (3) by pulling the locking antenna connector (2) away from the radio (1). 7.Remove the radio.
REMOVAL
