[5th Gen : 08+]: 2012 headrest airbag
Old Nov 8, 2014 | 03:54 PM
nightrider23's Avatar
nightrider23
Default 2012 headrest airbag
I was removing the drivers seat headrest to install a seat cover and I pulled the headrest airbag wires out of the yellow connector plug. On the headrest side there is a yellow wire and a brown wire. On the seat side there is a red/black wire and a pink/white wire. These dual colored wires I need to reinstall in the yellow plug but I need to get them on the correct side of the plug to match up with the brown and yellow wire. Does any one have a wiring schematic to show this connection.
mark
2012 grandcaravan
Old Nov 9, 2014 | 09:56 AM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
be careful I would think it could trip or damage. look at both connectors they should have a one directional connection. they would not allow you to plug it in to the wrong way. also if you really want to make sure I think you need to take off the battery for atleast 10 to 15min to drain off the capacitors. then can try plug it in. but like I said should only go in one way]
Old Nov 9, 2014 | 01:29 PM
nightrider23
When I was removing the headrest I didn't know there was an airbag. So when I pulled it out it stuck a little so I pulled hard and it came out fast and I ended up pulling the wires completely out of the plug. So when I reinstall the striped wires in the plug I need to put the wires correctly in the plug to match up with the yellow and brown wire. I've looked on the internet for a free wiring schematic but no luck, so I'm going to try the library next week.
