[5th Gen : 08+]: 2013 caravan grinding sound when braking
Old Nov 12, 2014 | 02:18 PM
akuster1987's Avatar
akuster1987
Default 2013 caravan grinding sound when braking
just noticed a few days ago when i stopped at a stop sign, i heard a grinding sound. thought it was the brake pads, but they are fine and the rotors are still good. so idk what it could be. Its only when I'm stopping at a light/stop sign.
Old Nov 12, 2014 | 02:42 PM
Is it right after you start driving? Does it stop after awhile? Moisture accumulates on the rotors and can cause slight surface rust overnight. First time you use the brakes, you hear a gringing as the pads scuff off the surface rust. My car does that.
Old Nov 12, 2014 | 07:21 PM
smokesxt's Avatar
smokesxt
It's also possible that some grit (small stone/sand) got between the rotors and pads, I've had this happen and it sounds horrible.
I'm assuming you checked pads both inside and outside the rotor?
Old Nov 21, 2014 | 05:40 PM
Montreal300's Avatar
Montreal300
Have the parking brake checked to see if the shoes have delaminated.
