[4th Gen : 01-07]: Should I RTV area on lower intake manifold
2005 dodge caravan with 100k miles. I have a coolant leak seems to be on an area of the intake manifold where it is pitted and not flat and smooth. Seems like it was like this from the factory. I got a new felpro gasket but I was wondering if I should also rtv over the area where it is pitted and not smooth. I cleaned it as good as possible but you can still see where the area is pitted.
"""Seems like it was like this from the factory."""
That is called Cavitation. From a coolant leak that has been escaping from that surface for an extended time.
If it's deep, I would just get another manifold. A salvage yard one will be fine.
Spread some RTV, let it haze for a bit, then torque down.
