[4th Gen : 01-07]: 06 4 cyl caravan died no start
I have a 2006 caravan that stopped running while driving. I changed the fuel pump and relay but still wont start. I am looking at the crank sensor next but sol on what to do next. could it be the pcm ? Help need car for work can't afford to take to shop thanks Ron
Ok first II forgot to tell there were no codes. Tow truck driver said he got 03 code from turning ign on and off 3 times than he banged on the gas tank.
I have changed gas pump do to not hearing pump turn on while trying to start car. second changed relay still no start checked if spark from plugs no spark changed crank sensor no spark. other things to check but don't know how is timing belt, coil pack and pcm. So what ever you can think and how to fix it would be helpful thanks ron
