[4th Gen : 01-07]: Air Bag Light Stays On- Where are Front Sensors
Old Feb 21, 2015 | 04:36 PM
mal2's Avatar
mal2
Default Air Bag Light Stays On- Where are Front Sensors
I have a 2004 Dodge Grand Caravan, base model, 3.3.
Purchased 2 years ago. Airbag would come on intermittently.
Light is now lit permanently.
Changed clockspring, light remains on. Horn, cruise, tach still operate properly.
I want to check connections at front impact sensors but can not locate. Can anyone assist?
Old Feb 22, 2015 | 03:50 PM
Cougar41's Avatar
Cougar41
This is for an 03 but gives you three choices. Front grill, lower radiator frame or in the ORC module itself. 04 wire diagram shows separate left/right front sensors both two wire connectors. Right - white/lt blue and violet/lt blue wire ID. Left - lt blue/white and lt blue/violet. Have you checked to see what code is turning on the light? The code will tell you where to go.
http://www.justanswer.com/dodge/2koa...ated-just.html
Examples: http://www.amazon.com/s/ref=nb_sb_no...airbag+scanner
