[General]: seat belt
Old Apr 12, 2015 | 09:45 AM
pappyken's Avatar
pappyken
Default seat belt
I have a problem with my 2005 caravan drivers side seat belt, it hooks up properly but it takes about 30 seconds of struggling with it to unlock, do I need a new belt, a new receiver or is there a way to fix this.
Old Apr 13, 2015 | 12:18 PM
Tizzy1's Avatar
Tizzy1
have seen change fall into the slot and cause that issue
Old Apr 14, 2015 | 09:00 AM
pappyken's Avatar
pappyken
It would be impossible for any coin to fall into that slot.
Old Apr 14, 2015 | 09:37 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
DIMES fit perfectly in that slot. If I had a nickel for every one I've pulled out...
The lock mechanism is probably bent or something. Get a new buckle.
Now is also the time to recognize that you need to keep a device in your glove box that can CUT a seat belt and break a window in an emergency.
Old Apr 22, 2015 | 05:12 PM
digieman's Avatar
digieman
Default Wd 40
Have you tried spraying some WD40 In the latch, that's what it's for.
Old Apr 23, 2015 | 08:18 AM
pappyken's Avatar
pappyken
I dont use WD40 its very unreliable, but I used another brand of lube and now my belt works fine. thanks
