[4th Gen : 01-07]: radiator speeds
Old Apr 16, 2015 | 09:53 PM
frankvilla30's Avatar
frankvilla30
Default radiator speeds
i have an 03 carvan both fans turn on 30% when the van starts but when the a/c turns on only the drivers side runs 100% should the passenger side also run 100% or just a low speed... my a/c cuts off when the van reaches a certain temp druing the day but at night and on a cloudy day it runs great cold a/c.
Old Apr 17, 2015 | 09:44 AM
Usually in a two fan system, one fan is multiple speed, the other is constant speed. If you are not experiencing any overheating issues, I would not worry about it.
Old Apr 17, 2015 | 03:29 PM
Cougar41's Avatar
Cougar41
Looking at a wire diagram I'm not seeing separate controllers for each fan. Both fans are controlled by a single output from the rad fan control relay. Might try spinning the fans by hand to see if one is binding.
Old Apr 19, 2015 | 12:52 PM
frankvilla30
thank you guys.. its not overheating but since the A/C shuts off and wont restart till after the van has reached a certain temp. took it to the mechanic they have no clue ehat it is.
Old Apr 19, 2015 | 01:25 PM
Maybe it's perfectly normal.
