[4th Gen : 01-07]: No Start - No Power to Starter
Old May 4, 2015 | 08:26 PM
jamejedi's Avatar
jamejedi
Default No Start - No Power to Starter
Hi,
Hoping for some help. Van will not start. I do not have power going to the solenoid, battery is good, as is the relay.
What else could it be? Thanks for any help!
Old May 5, 2015 | 06:48 AM
jamejedi's Avatar
jamejedi
I did the "hold the odometer button" thing, the codes that appeared were Sof8.3, Error code 100.6? not sure what they mean.
There are no CEL codes stored, but I did remove the battery for testing. I am having a hard time with this.
Old May 5, 2015 | 09:24 AM
DodgeCACares's Avatar
DodgeCACares
Originally Posted by jamejedi
Hi,
jamejedi,
I'm sorry to hear about your starting issue. What model year is your van? What engine do you have?
Old May 5, 2015 | 09:51 AM
jamejedi's Avatar
jamejedi
Hi,
Thanks for the reply. It is a 2007 Grand Caravan with a 3.3. CEL is on, but my OBDII code reader does not show any stored codes.
I went through the "odometer test" and found; Sof 8.3 - I think this is the software version?
Also, I found this code information, hopefully it is accurate? It was posted for a 2003 Dodge Caravan
100.0 LOOP-BACK FAILURE
100.6 SBEC/DEC/MCM COMMUNICATION FAULT
Not sure what they mean?
Old May 5, 2015 | 11:41 AM
DodgeCACares
Hi,
jamejedi,
Thank you for the additional details. The Sof 8.3 is the software version. The 100.6 code displayed is a SBEC/DEC/MCM Communication Fault. With the vehicle being non-responsive, a formal diagnosis would be beneficial in order to efficiently pinpoint the root cause.
Old May 5, 2015 | 12:09 PM
jamejedi's Avatar
jamejedi
Thanks for the reply. I am trying very hard to avoid the dealership diagnostics.
Is there a way to test ECM and PCM? Does the 07 have the PCM, mine looks different from others that I have looked at. Also, does this look normal?
Old May 5, 2015 | 01:13 PM
jamejedi's Avatar
jamejedi
I am about to throw in the towel. Do I need to go to a Chrysler dealership? Is there any real benefit using their scan tools vs. a local garage?
Thanks for all the help. I will post the results once they are known.
Old May 5, 2015 | 02:44 PM
DodgeCACares
jamejedi,
Dodge dealers specialize in FCA products and have the training necessary, as well as a wide range of resources available to them in order to diagnose and address vehicle concerns in an efficient manner.
Old May 5, 2015 | 03:34 PM
jamejedi's Avatar
jamejedi
Well....the garage that I used before is going to try. The wrench on the phone said they have the correct diagnostic tools for the job. Time will tell. I will update when done.
Old May 5, 2015 | 04:52 PM
Cougar41's Avatar
Cougar41
The majority of start circuit problems can be troubleshot from the starter relay socket on the IPM panel. Have you jumped contacts 30 and 87 at the starter relay socket? Starter should spin with keys in your pocket. This bypasses the control circuit to the relay. Are you getting 12vdc at contact 86 with the key at start? That's voltage from your ignition switch.
