[4th Gen : 01-07]: How much 3 dot brake fluid do I need to purge all the old fluid out
Old May 10, 2015 | 06:25 PM
riverjamie's Avatar
riverjamie
Default How much 3 dot brake fluid do I need to purge all the old fluid out
I have a 2001 Dodge Grand Caravan with rear drums. How much fluid is needed to completely purge the whole system? Thanks
Old May 11, 2015 | 07:19 AM
kuyabribri's Avatar
kuyabribri
If you've never done this before I suggest having 2 of the big 32oz bottles (or one 32oz and one 12oz) on hand just in case. But you probably can do it with just one of those big bottles and if you don't open the second one return it.
Old May 12, 2015 | 05:30 PM
Tizzy1's Avatar
Tizzy1
If it's not contaminated, I wouldn't waste my time.
Old May 12, 2015 | 09:05 PM
riverjamie's Avatar
riverjamie
Tizzy I don't think it's ever been changed in 13 yrs. So does look to good. Also replacing both rear brake cylinders. Show a little leakage.
Old May 15, 2015 | 09:37 PM
Marcus71's Avatar
Marcus71
If it shows a little leakage, there's a good chance contamination got in to the fluid, if it were me, I would replace it. The last thing you need is for water to get in through the leak and reduce your boiling point.
