[3rd Gen : 96-00]: 99 Grand caravan no spark
Old May 28, 2015 | 07:16 PM
Seattleguy's Avatar
Seattleguy
Default 99 Grand caravan no spark
Greetings
My apologies that this must be the most common problem and question, I've searched the Internet but most answers are full of jargon, so undecipherable.
99 Dodge Grand Caravan
Upon advice from various PAID mechanics I have :
Compression check good
Replaced the battery
replaced the starter
replaced the crank sensor
replaced the coil
replaced the (front) spark plugs
Still no spark
fuel rail has good pressure
I can hear the fuel pump start
The "mechanic" checked for codes, there are none shown
The shut off relay vibrates continuously, swapped out the air conditioning relay gives the same result.
whats next?
Old May 29, 2015 | 08:47 AM
kuyabribri's Avatar
kuyabribri
How did you diagnose no spark, and were the plug wires replaced? If you replaced all that stuff and the wires and you still have no spark your problem is likely upstream of the coil, and that would be hard to diagnose without looking at the car with a multimeter.
I don't know if you are looking to repair this yourself or just seeking information to arm yourself with for a trip to a mechanic. But if the answers you found to this issue on an internet search are "undecipherable jargon" to you, for your own safety I would not recommend doing this yourself, or at the least get a Haynes or Chilton repair manual.
