[5th Gen : 08+]: Rear hatch wont open
Old Jun 6, 2015 | 11:02 AM
p_barrette's Avatar
p_barrette
Default Rear hatch wont open
2010 Grand caravan sxt
Cant get my rear lift-gate to open. I have been reading through the forum for a couple days and just cant seem to find a thread that has had my issue.
The gate is down and locked and will not open with the fob, over head button or manual handle on the gate itself. I've removed the small access panel inside and have tried pulling and pushing on the release leaver at the latch itself. The leaver moves freely but will not release the gate.
I'm at a loss guys, any help would be appreciated.
Old Jun 7, 2015 | 09:09 AM
p_barrette's Avatar
p_barrette
Well after much playing around with it I finnaly got it open.
Removed the latch assembly worked the mechanism manually and nothing seems to be sticking anywhere. Tested the motor direct with 12v and it is working as well.
It's starting to look like an electrical issue to me. Dose anyone have or know where I can get a schematic for this system?
Old Jun 7, 2015 | 01:40 PM
p_barrette's Avatar
p_barrette
Default Solved
Would like to post my solution with the hopes that someone else encountering this problem may find this post.
Behind the scissor jack compartment lies the Liftgate control module. There was a lot of corrosion in one of the connectors to the point that one wire was completely broke off. Quick clean and solder job it's back in service.
Old Jun 7, 2015 | 04:20 PM
georgef's Avatar
georgef
Thanks for posting the fix, I'm sure it will help someone out in the future.
Old Jun 8, 2015 | 03:22 PM
DodgeCares's Avatar
DodgeCares
Thanks for posting your fix, p_barrette, it's appreciated!
