[4th Gen : 01-07]: Help Please! No Codes No Spark??????? 2003 2.4 Carvan SE
Old Jun 19, 2015 | 10:07 PM
jans41's Avatar
jans41
Default Help Please! No Codes No Spark??????? 2003 2.4 Carvan SE
I need help
I can not diagnose this problem it Caravan never had an issue before this but last week it just shut off while driving on the highway.
No codes show up on the scan. So I really have no idea what the problem is.
Engine turns over but no current at the plug?
Things I have tried so far:
has correct fuel pressure, New coil, new ASD relay, new plug wires, new coil pack, new cam sensor, new crank sensor, and I have even switched out the ecm with a new reprogrammed one still no start?
Please any ideas? I do not know what else to do....
Old Jun 22, 2015 | 01:00 AM
Cougar41's Avatar
Cougar41
"Engine turns over but no current at the plug?" Which plug? Do you mean voltage/power?
Are you getting fuel IN the cylinders and spark?
