[5th Gen : 08+]: Cruise Control Issue...Help Please
Old Jun 30, 2015 | 09:04 PM
Dodge2008's Avatar
Dodge2008
Default Cruise Control Issue...Help Please
Hi, Novice here....I have a 2011 Dodge Grand Caravan Crew. For the last month or so, the cruise control will not turn on when the button is pressed. This happens intermittently. If the van is turned off and back on it may randomly work. Seems to not be working more often though. Everything else has been functioning fine. Only exception was a check battery light that went away when the mechanic cleaned the terminals (was tested ok, battery and charging etc)
Does it sound like a bad button? Any idea on cost? My worst fear is that it is the PCM because I don't believe that is covered under warranty at this point? Thanks so much everyone for the insight.
