[4th Gen : 01-07]: abs light on
Old Jul 23, 2015 | 11:36 AM
looty's Avatar
looty
Default abs light on
hi ..i have dodge caravan 2005, abs light came on 2 weeks ago i want to know what faults activate this light, also i need to know how to check the sensors using digital multimeter for this van....thanks in advance.
Old Jul 23, 2015 | 11:53 AM
MarkWilliams64's Avatar
MarkWilliams64
I had this happen to my 2007 Grand Caravan, by chance has your Traction Control Switched off as well.
I took it to a Mechanic that Scanned the ABS Code, can't remember the Code #, but he was able to isolate it to the Drivers Rear Wheel. I replaced the ABS Wire/Connector to the Hub and the Code went away.
Just need someone who can scan ABS Codes for you.
Good Luck
Old Jul 23, 2015 | 04:17 PM
looty's Avatar
looty
thanks mark i think i should do that.
