[5th Gen : 08+]: Bad Wire Harness?
Old Sep 2, 2015 | 06:30 PM
galwaygirlatheart's Avatar
galwaygirlatheart
Unhappy Bad Wire Harness?
Please help! My van has been at multiple dealerships since April for the same problem. It's an 09 Grand Caravan with over 100k miles on it. It's had a new throttle boy, Map Sensor, Cam and Crank Sensor, EGR, TIPM, plugs and wires, ignition switch and a complete wire test done. But it's still stalling intermittently. You can drive it one day with no stalling and the next it can stall 5 times at stop lights and signs and when your slowing down. The dealership it's at now discovered that if you turned the AC on it would stall within one minute which leads him to believe it's an electrical issue. He had the ECM tested and that came back fine, so now he believes it's the wire harness. I'm praying he's right because that's almost $900 and we've already put 2300 into this. Any help would be so appreciated! Thank you!
Old Sep 3, 2015 | 12:58 PM
Cougar41's Avatar
Cougar41
Not sure of the current status of this investigation: http://www.usatoday.com/story/money/...htsa/16496795/
There is also a class action lawsuit against Chrysler regarding TIPMs and stalling. Status unknown. As I recall it involves a faulty fuel pump relay in the TIPM.
Your TIPM was replaced but did they just install a new TIPM with the same problem?????
