[4th Gen : 01-07]: Solved Grand Caravan Crazy gauges
Old Sep 3, 2015 | 02:08 PM
FRR's Avatar
FRR
Default Solved Grand Caravan Crazy gauges
I was told after my guages and lights started going crazy and my engine stalling and dying out and my transmission was not shifting gears right like they should that my problem was a torque converter lock up killing my engine. Plus, the shift sensors were bad, Plus the cam and crank sensors were bad and bad fuel pump also from professional mechanics i took it own my own to fix it. I found a computer code and it said it was a computer memory error. You need a new ECM. I went to the salvage yard and for 25 dollars i installed it and the car runs now like a brand new one. No need for any programming at all. Just plugged it up and it worked like brand new. I felt others needed to know this.
