[4th Gen : 01-07]: 06 Grand Caravan No passenger low beams
Old Nov 14, 2015 | 06:39 PM
jakenlacey1127's Avatar
jakenlacey1127
Default 06 Grand Caravan No passenger low beams
Hi all, I have a problem with my 2006 Grand Caravan that is causing a huge headache. The low beam light on passenger side isnt working. Here's what I have done: Replaced bulb, Checked and cleaned the ground wire under battery box, cleaned both battery cables, check wire from light to fuse box with multi meter, and replaced the front control module. Now I have no idea what to do, please help. Thanks so much
P.s. There is also another problem with the instrument panel going crazy at random times when driving. Lights flicker, gauges go crazy. Not sure if this is related but fixing low beam is more important to me at the moment.
Old Oct 26, 2018 | 01:43 PM
banjo_d's Avatar
banjo_d
remove and clean the contacts on your ECM. I had a similar issue and this fixed it!
Old Nov 3, 2018 | 03:55 PM
RickMN's Avatar
RickMN
Check ground G300 on left "B" pillar (wiring diagram)
