[General]: Time and resource efficient radiator flush?
Old Dec 16, 2015 | 09:51 PM
tjnc's Avatar
tjnc
Default Time and resource efficient radiator flush?
I take the thermostat out and use distilled water with the heat going a couple times then put a new thermostat and gasket in with some 50/50 g-05(4Gal).
I don't use a flush chemical.
Is there a better method? I've seen older mechanics use a garden hose for the pressure to get it more clean with the vehicle off. I guess this doesn't do heater core.
Old Dec 17, 2015 | 07:35 AM
Are you draining it out and refilling? You don't specify. A backflush would be better IMO. You can buy kits to do this.
