'97 Voyager - spark plug question
Old Nov 6, 2005 | 12:37 PM
nicomp's Avatar
nicomp
Default '97 Voyager - spark plug question
What tools do I need to remove the plugs from the 3.0L? They are tucked back toward the firewall and are not easliy accessible. I'm sure there's a secret tool that will make this job easy?
Thanks,
Bill
Old Nov 7, 2005 | 09:28 PM
Toecutter's Avatar
Toecutter
Default RE: '97 Voyager - spark plug question
Bill,
Look through this Van Forum. Your answer will be in here somewhere, It DOES Take awhile to do.
Some Suggest removing the 'Plenum' to get to the back left plug. I did my 96 as well took awhile to do for the first time.
But its do-able must have patience my padayon learner. Don't forget its ok to cuss and throw you tools after the first 20 min on that plug.
I found that I needed or could have used a set of spark plug pliers prob woulda help w/ the new boots I put on.
I'll surf this Caravan forum. Or here's an idea look for all my posts and one of them should point you in the right direction.
Toe.
Old Nov 7, 2005 | 09:38 PM
Toecutter's Avatar
Toecutter
BINGO!
Look here Bill,
https://dodgeforum.com/m_224559/mpag.../tm.htm#224559
PS. Mitsubishi makes that engine if I'm not mistaken...... SO I use NGK's in my ride something to ponder.
Toe
