[4th Gen : 01-07]: Power Steering Shudder
Old Jan 8, 2016 | 11:30 AM
jamejedi's Avatar
jamejedi
Default Power Steering Shudder
Hi,
I just replaced the power steering fluid. I disconnected the return line and pumped fluid into a pan. Since I have replaced the fluid, I now have a "shudder" when turning the wheel.
Is there air in the system? I did not raise the front end and turn the wheels, could this be the issue?
Thanks
Old Jan 9, 2016 | 08:46 AM
jamejedi's Avatar
jamejedi
bump to the top
Old Jan 9, 2016 | 01:51 PM
jamejedi's Avatar
jamejedi
Today, I replaced the power steering reservoir after researching that it could solve the problem. The shudder improved a little, as did the whine. However, there is still a shudder/sputter when turning the wheel at low speeds.
Any thoughts?
Old Jan 11, 2016 | 04:50 PM
Tizzy1's Avatar
Tizzy1
Air in the system is some of the cause. It is also very common and hard to get rid of once you have it. I have a vacuum pump with a rubber stopper that I use to apply a vacuum to the system and remove the air. I can take up to 5 minutes of vacuum to remove all the air.
Old Jan 12, 2016 | 09:15 AM
jamejedi's Avatar
jamejedi
Thanks for the reply. I own a vac pump, not sure if a friend still has it. I will see if I can find it, and try it. Thanks.
