[4th Gen : 01-07]: 2006-2007 Caravan Fuse box connector replacement
Old Feb 24, 2016 | 12:00 PM
wilcom's Avatar
wilcom
Default 2006-2007 Caravan Fuse box connector replacement
I have a 2007 Caravan with a bad Fuse box and bad fuse box connector. I was able to get the fuse box, but when I was replacing I found a connector on the wiring harness that is broken and unusable.
I have called 40 junk yards in Southern Ca. looking for a 06-07- Caravan or Town & Country to get a piece of the wiring harness......... NO LUCK at any junk yard.
Are those connectors common with earlier models?( I know the fuse box is not) or does anyone have a source for the connector by itself, I would rather splice in a tail and connector rather than buid a new connector
thanks for any help
Joe
" with no headlights or blinkers and one tail light ... arrrrgh"
Old Feb 24, 2016 | 08:17 PM
georgef's Avatar
georgef
To get the part number for the connectors got to: http://connectors.dcctools.com/
Enter 2007 for year and RS: CARAVAN / TOWN & COUNTRY for the platform then click FIND NOW.
In the "Filter these results" box enter integrated power module.
You will be presented with a list of all the connectors for the fuse box, click on the one you need and it will either show a repair kit number or "repair kit not available". You can purchase the repair kit from a dealer or search for a source online.
You can also find the part number for earlier models to see if they are the same as the 2007.
Old Feb 25, 2016 | 07:05 PM
Cougar41's Avatar
Cougar41
Nice. Thanks for the tip.
Old Mar 19, 2016 | 02:57 PM
wilcom's Avatar
wilcom
I replaced the fuse box and connector today. Same problem exists, no tail lights no rear blinkers(fronts blinking fast like a burned out bulb) and no left brake light The only thing I gained is my left headlight is now working.. everything else is still fubar
Old Mar 19, 2016 | 04:47 PM
Cougar41's Avatar
Cougar41
Have you checked for power and ground at the light sockets with a meter or test light at the sockets?
