[4th Gen : 01-07]: P2308 after intake manifold gasket repair
Old Mar 1, 2016 | 01:26 PM
Cortman's Avatar
Cortman
Default P2308 after intake manifold gasket repair
I'd better start with a full confession in case any of this affects my current problem. I decided to do the intake manifold gasket repair myself and I did a full top end gasket replacement. So far so good.
Now the problems start. Got it started and it was running very rough. Realized i had crossed the ignition wires on the back 3 cylinders. Got that straightened out but it was still running rough tho not as bad. Pulled the #6 wire off the coil in the front while it was running. NO SPARK. Pulled #4 just to be sure. That one had spark. Ow! Threw P2308 code.
Had the van idling for a minute while adding water and it died like you would have turned the key off. Replaced coil pack, but no good news. Still dead. Cranks fine, but I think it an ignition issue. It has new plugs and wires on it too. Any ideas what I did wrong?
Old Mar 7, 2016 | 02:24 PM
Cortman's Avatar
Cortman
Ok. I pinched a wire that goes to the plug into the back of the coil. Repaired that and I am back up and running again. This forum is rubbish as far as helpful advice goes. I don't think I will waste my time posting problems on here again.
Old Mar 7, 2016 | 04:02 PM
Tizzy1's Avatar
Tizzy1
I'm sure I'd rather have 30 people throw wild guesses trying to figure out what I screwed up.
